Rapid code to generate a backup.
I want to have my robot automaticaly generate a system backup. Is there rapid instructions for this that I can add to my main program? I don't need to backup to a network drive, simply adding it to the default backup directory on the controller will sufice.
Mel
  • Hello,
    That functionality is not available right now, but there is a new function in RobotWare 5.13 that does this. Robotware5.13 will be released in Q2 this year, so please be patient!
    BR frpa
  • I downloaded 5.13 and interested in the rapid backup function. Do you know where I can find exaples or literature on this?
    • System Input/Output for Backup
    A new System Input called Backup is available from RW5.13. When a digital I/O signal connected to the System Input Backup is set a backup will be started. Name, path and an argument telling if the backup name shall be unique or overwritten, must be configured.
    A new System Output called Backup in progress is available from RW5.13. The digital I/O signal connected to the System Output Backup in progress will be set while a backup is in progress.
    A new System Output called Backup Error is available from RW5.13. The digital I/O signal connected to the System Output Backup Error when the system detects a backup failure.
    BR
  • This autobackup feature works great. Way to go ABB!!
    Mel
