replace name with num value
I have a slight problem, i have a randomGenerator witch gives me a number between 0 and 200. And i have 200 routines named "routine1, routine2" etc. And i want to do the rutin by random from the number i get from the randomGen. So to my question:
How do i replace the number 1 in routne1 with the value i get from my randomGen?
BR
  • you could make a routine that accepts your number and use test / case to run each of your individual routines..
    TEST RandonNum
    CASE 1 :
    Routine1;
    CASE 2:
    Routine2;
    ENDTEST
    little bit tedious.. but without know what your doing with the 200 routines i cant think of much better.
  • Hello,
    You can use something called late binding to do this in a much simpler way. Please see the following example code:
    randomNumber :=GetRandomNumber;
    routineName := "Routine" + NumToStr(randomNumber, 0);
    %routineName%;
    This will call the routine with the name "Routine1" (if randomNumber is 1).
    Good luck!
    BR frpa
  • Hi
    You can use
    CallByVar - Call a procedure by a variable
    Example
    reg1 := 2;
    CallByVar "proc", reg1;
    Regards
    Knud Erik Lindberg
    Danrobotics
