Block Buttons
jjsg
in ScreenMaker
Hello;
Is possible block some functions/buttons in auto.
Like if i have a button that setup one output, and I want do that only if the Robot is in manual mode.
Best Regards:
JosAc GonA?alves
Hello:You can use the IO system signal for manual mode ( AUTO / MANUAL) to enable & disable controls.Best Regards,Srini0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
