Russian 'Cyrillic alphabet' in robot!!
Jaaahhh
Robotware : 'RobotWare_5.12.03
I have a problem, I want to change the string 'strTotalReset' with Russian characters.
PERS string strTotalReset :="Total reset";
strTotalReset :="DYD_D?D??
After I load this data in the robot I get the error message in 'Robotstudio'.
It's not possible to save the program.
Can I use the Cyrillic alphabet in a string?
Best Regards,
We just had this problem last week. The reply from ABB is that RAPID does not handle Cyrillic fonts..If you find a solution please let me know:)Jaeger2010-03-02 15:37:080
He Jaeger,
Thanks for the Reaction.
For me the solution is to handle the language in the Flexpendant. I must write an error on the screen for a operator. I will handle the error's in a .Net application instead of using Rapid instruction's that can only handle ASCII.
Best Regards,
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
