Button With Error Indication
jjsg
in ScreenMaker
Hello;
When I press a button I want that it becames red, if the action it's not possible ( the error information will be send to Screen maker using a do_error)
Is possible?
Best Regards:
JosAc gonA?alves
Hello,If i understand correctly, color of the button should change based on the state of the signal.1.Button Control has a AllowMutipleStates property.Set the property to true and select the property (ex: BackColor) by clicking on the checkbox.2.Bind the signal to SelectedStateValue property.3.Define States of the Signal using States property. For example:if 0 define color (blue)if 1 define color(red)So when the state of signal is 0 the backcolor of button changes to blue and when 1 changes to red.0
Hello;
Yes is more or less that.
But the idea it was only change to red color, when the button is pressed (if the digital imput is 1)
BR:
JosAc
Hello,You can try the steps mentioned in the earlier post.Thanks0
