Extended work range
In my system builder I've chosen the option extended work range axis 1 (+/- 220 deg), including EPS.
However, in robotstudio the work range is still a range from +/-170 deg.
Where can I change (increase) these work range for axis 1?
The Robot Used is an IRB6640.
kind Regards,
vanuitert
  • Hi,
    RobotStudio will update the simulation model according to the limits of the controller. This becomes very obvious if you first import the library for the 6640 (limits are +-170), use the function "System From Layout" to create the system, in the wizard add the option "Extendend working range." When the system starts you get the message "IRB6640_180_255__03: The limits of joint 1 were updated to system values because it differed between system and station model limits. " in the Output windows. And if you check the limits using the joint jog tool you will see that they have been updated to +-220.
    ABB
