MTC 2000
rixmaia
I need the library of MTC2000 for RobotStudio 5.12.
The file available on the website of ABB seem to have a previous version.
Can you help?
Can you help?
Thanks, Ricardo
No more one word!
Hi Ricardo,
You can import old libraries (.rlb) in RobotStudio 5.12. Open the Import Library dialog and change the file filter to "RobotStudio 2.x/3.x libraries".
regards,
Johannes
Johannes Weiman
Thanks Johnnes!!!But in the window "Select library for type default" not have the option to use the old files.Thanks in advance again!!!BR, Ricardo
rixmaia2010-03-10 18:59:28No more one word!0 -
What about loading the old RobotStudio library separately and store it as new RobotStudio 5 library and then start the VC ?//Volker0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
