Force Control for Maching
marthin
Hi!
Has anyone succeded in teaching and learning a path around an circular object.
When trying the robot gives up after 90 degrees around the circle and just taking off out from the circle. Seems like the robot putting pressure in the direction of the first point where it is activated.
I have seen it been done on the web, so it must be possible.
Watch 2.15 minutes into this:
http://www.youtube.com/watch?v=HW1j2mk8uyY&feature=related<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Any ideas?
Marthin
Hello,From Austria:
I have done a movie for you in the lab. In the video everything is shown what is important for creating a Force Control path on a cylindric part.
I have attched for you also the program what is shown in the movie. I have used FCPressC for the program but also run the system with FCPressL, but you need more points on the curvature if you like to use FCPressL.webwiz/222/FC_Circle_Video.zipAre you using the Path force reference?BR / Jim Proulx0
- 367 IRC5
- 858 RAPID Programming
