XML Read
I am sure it must be easy but......Cry
I am trying to read an XML file with RAB builder in vb.Net, the problem is that when I set the instruction ' m_xmlr.Read()' the program jumps to the catch instruction and I get the following error.
This is my program code!
Imports System.Xml
Dim m_xmlr As XmlTextReader
Sub Read_XML()
  Try
    ' Create the XML Reader
    m_xmlr = New XmlTextReader(xmlFile)
    ' Read the XML file
    m_xmlr.Read()
    ' The rest of the code is not implemented.......
Catch ex As Exception
  GTPUMessageBox.Show(Nothing, Nothing, ex.ToString, "Debug", System.Windows.Forms.MessageBoxIcon.Exclamation, System.Windows.Forms.MessageBoxButtons.OK)
End Try
Endsub
Best Regards,
Edwin,
  • Hi,
    I found this sample on MSDN, which shows how to configure the XmlReader to be able to access a file on the web (which I know is not what you are doing) ;
    " Create the reader.
        Dim reader as XmlTextReader = new XmlTextReader("http://myServer/data/books.xml")
        ' Supply the credentials necessary to access the Web server.
        Dim resolver as XmlUrlResolver = new XmlUrlResolver()
        resolver.Credentials = CredentialCache.DefaultCredentials
        reader.XmlResolver = resolver
    From what I could understand the reader also tries to resolve references to Schemas, specified in the XML file over the web.
    Its a long shot, but try to set the XmlTextReader.Resolver to Nothing/Null, and make sure your file path is valid so its not mistaken for a resource on the web for some strange reason.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Hello,
    I am still having the problem. On the VC I can set the path as =>
    objMessages =
    New clsMessages("D:CsiProjects empTest_PM_IzhoraHOMEError_Log_Ru.xml")
    My appl. works perfectly!
    Now the problem, what must it be on a real controller? I tried =>
    'objMessages = New clsMessages("Error_Log_Ru.xml") ' Does not work!!!!!
    'objMessages = New clsMessages("home:/Error_Log_Ru.xml") ' Werkt niet!!!!!
    'objMessages = New clsMessages("/hd0a/66Z-51925/HOME/Error_Log_Ru.xml") ' Does not work!!!!!
    'objMessages = New clsMessages("/hd0a/66Z-51925/home/Error_Log_Ru.xml") Does not work!!!!!
    What is the correct path name??
    Best Regards,
  • Hi Jaaahh,
    the FlexPendant device itself is a separate computer compared to the IRC5 controller.
    So when you write code like "new FileStream(path, FileMode.Open);" the path specified can not be a path on the controller file system.
    Basically you have to get the file from the controller to the FlexPendant using the Controller.FileSystem class which provides FTP-like functionality.
    Then you can open the file on the FlexPendant.
    Example:
    [CODE]FileStream fs = null;
    if (this._Controller.IsVirtual)
    fs = new FileStream(this._HomeDir + "/mpLocation.mod", FileMode.Open);
    else
    // on the real controller, get the file first
    FileSystem fsys = this._Controller.FileSystem;
    fsys.RemoteDirectory = this._HomeDir;
    fsys.GetFile("mpLocation.mod", "/Temp/" + "mpLocation.mod");
    fs = new FileStream("/Temp/" + "mpLocation.mod", FileMode.Open);
    [/CODE]
    There may be a better way to handle the VC/RC issue than the one in my example. I'll check that and come back.
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Hi guys,
    I want to log the error in to the "Event log".
    I know the list of errors in my applications.
    I would like to create a XML file to list out my all the application errors.
    While running my applications any error occurs, I would like to log in to the event log.
    Which will be helpful for me to trace what happened in the process.
    Guide me. Thank you.
    Lingaa
  • Hi,
    do you want your software to create event log entries, or save all entries (or some of them) to an XML file?
    ABB Robotics
    Developer Center
    RobotStudio Blog
