FlexPendant Interface
qweq
Hi all
Maybe it is just me being stupid but..
I'm trying to write a bachelor project where I need to make the robot follow an object moving via a webcam.
I have made an application that can start and stop rapid task.
But now I want to use the messaging domain to message the robot where to move, since this is going to happen a lot.
I all the time get the error FlexPendant Interface is missing..
I have search the internet thin and all I can find is people saying that this option is missing and that it should be added, but not how to do it..
I read that a lot of people create a virtual robot with this option, again maybe it's just me, but I can't find/see this option anywhere.
I have installed the needed tools from RobotWare 5.12.04 and using MS VS2008 to create my application..
I hope some of you can enlighten me on this, since I really need this.
I have changed the RMQ Type to remote as per what the manual says.
I followed the manual regarding messaging. So I thought that it should work pretty easily.
Thank you
qweq2010-04-02 11:57:07
To use your Application on a real controller you need to have the RobotWare Option "617-1 FlexPendant Interface". FlexPendant Interface provides the possibility to download and run user-developed operator interfaces on the FlexPendant. Get in contact with your ABB representative and purchase that option. You need to reboot your robot controller to activate the option.
Thank you for your reply..I figured out howto add it in robotstudio.And I hope my university have this addition
Hi,Can you tell me how you solved this problem? Cause I'm having the same problem that you had.I'm also working on a bachelor project to make the robot follow an object with a 3D time of flight camera.I'm also having a warning : RMQ message discarded.Regards,0
Sorry for the late answer...
Hope you can still use it
I basicly, just used the build function to build a robot from a template and added the interface..
Build station --> choose interface..
Also, remember to start the rapid task and move the PP to main,
at least this is what I have experienced makes the warning go away
- 367 IRC5
- 858 RAPID Programming
