instructions error
Need help.
instructions error
Description
TASK T_ROB1: variable and trap routine already connected
Actions
It is not legal to connect a specific variable with a trap routine more than once
I feel i must write an error handler but i m not so experienced in RAPID programming.  It is needed to automatically restart execution of processes.
Programm looks like (simple)
MODULE module1
     workobjectdata ........
     targetsdata ..............
     tooldata.....
     speeddata....
PROC main()
      path1;
      path2;
END PROC
PROC path1()
       move instructions .....
END PROC
PROC path2()
        move instructions.....
END PROC
END MODULE
after execution of path1 and path2 i get the error i v mentioned above and i have to manually press ok to the error message, PP to main and start button. ANy advice how to automate this?
Thx.
  • Hi Dimitri,
    Do you have any intnum variable in your program.
    VAR intnum nVaribale;
    If you have one try to delete it at the end or begining of each cycle with IDelete command.
    IDelete nVaribale;
    BR.
    Erdem Karaçeper
  • Lol. this was simple)
    I have just to insert proccall (to main proc) at the end
    MODULE module1
         tooldata.....
         speeddata....
    PROC main()
          path1;
          path2;
    END PROC
    PROC path1()
    END PROC
    PROC path2()
            main;
    END PROC
    END MODULE
    So now i have endless cycle and operator must press stop manually to stop robot ;p
  • lemster68
    lemster68 ✭✭✭
    Greetings,
    This solution is not so good.  It will cause a execution stack overflow.  It is recursive; your call heirarchy has already started in the main and then you call main from within.  A better solution for an infinite loop would be:  WHILE (TRUE) DO
        Proc1;
        Proc2;
        ENDWHILE
    BR,
    Lee Justice
  • or if you wanted some control over it. You can set the robot to run in continous cycle instead of single execution and when it finished main it will start again.
