GraphicComponent Color
I'm trying to change the Color of a GraphicComponent from the ABB.Robotics.RobotStudio.Station namespace, but it raises an exception saying "The given key was not present in the dictionary." Did anyone encounter this serious headache problem ever ?
Some code ...
[CODE]
try{
GraphicComponent boxesGroup = activeStation.GraphicComponents["BoxGroup1"];
boxesGroup.Color = System.Drawing.Color.Red; //Raises the exception
catch(Exception ex){
[/CODE]
Hi,are you using VSTA or have you created your Add-In with Visual Studio?VSTA does not support using types from the Windows.Drawing namespace.To set the color of a graphic component you can use this method on the VSTABridge class:0
Thanks Niklas, that worked0
- 365 IRC5
- 38 AppStudio
