Teach target real time
Stijn
I have to teach targets to the controller (robot) while the robot is running.
Is this possible ?
Can anyone give me some example code how I have to do this ? (In C#)
I've already made the simple pc SDK to find all the controllers on the network in C#.
Regards,
hi,
you mean teaching as sending robtargets? if yes, then use Messaging in PC SDK.. there are examples how to do it in manual.
Yes I mean sending robtargets to the controller.Ok I'm gone try the example as described in the manual.Thanks for the helpregards,0 -
Hi,I'm using the IPC sample to send messages to the controller but I'm getting the warning RMQ message discarded.I've found the IPC sample here:Does anyone now how I can solve this problem ?Regard,0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
