Minimum distance - Path from curve
Hello Everyone,
When I create a path from curve and setting the minimum distance between the targets at 3, 2 or 1mm and max cord dev at 1mm, the targets generated have a distance of 5mm or more. For example, a circle with diam. of 400mm, min. dist. of 1mm and max cord. of 1mm create 70 targets (18mm between each target).
How to proceed to respect the minimum distance?
Thx
  • Hi,
    The minimum distance parameter seems to be respected in your case. There are 18 mm between the targets which is more than the specified minimum distance of 1 mm. The minimum distance parameter is used to limit the number of targets created.
    ABB
  • Hi,
    Thanks you for the answer,
    In this case, how to set the increments between targets at 1mm?
    Thx,
  • You can lower the max cord parameter to get more points. It is a measure of the deviation between the original curve and the robot path (approximated using linear and possibly circular segments.)
    ABB
  • Hi,
    If you want an exact distance of 1mm between each target along the curve, you should use the setting "Constant".
    ABB Robotics
  • Hi,
    I have checked in many menus and I found nothing about setting "Constant" distance between the targets. How does it possible to set this?
    Thx
  • Here it is:
    ABB Robotics
  • Hi
    In RS 4 you need to write your own addin that does this. Not to hard if you know VB programming.
    Per Svensson
    Consat Engineering
  • Unfortunately, the "Constant" option is only available in RobotStudio 5.x, not 4.0.
    ABB
