Teach target real time
I have to teach targets to the controller (robot) while the robot is running.
Is this possible ?
Can anyone give me some example code how I have to do this ? (In C#)
I've already made the simple pc SDK to find all the controllers on the network in C#.
Regards,
  • hi,
    you mean teaching as sending robtargets? if yes, then use Messaging in PC SDK.. there are examples how to do it in manual.
  • Hi,
    Yes I mean sending robtargets to the controller.
    Ok I'm gone try the example as described in the manual.
    Thanks for the help
    regards,
  • Hi,
    I'm using the IPC sample to send messages to the controller but I'm getting the warning RMQ message discarded.
    I've found the IPC sample here:
    Does anyone now how I can solve this problem ?
    Regard,
