FlexPendant Interface
Hi all
Maybe it is just me being stupid but..
I'm trying to write a bachelor project where I need to make the robot follow an object moving via a webcam.
I have made an application that can start and stop rapid task.
But now I want to use the messaging domain to message the robot where to move, since this is going to happen a lot.
I all the time get the error FlexPendant Interface is missing..
I have search the internet thin and all I can find is people saying that this option is missing and that it should be added, but not how to do it..
I read that a lot of people create a virtual robot with this option, again maybe it's just me, but I can't find/see this option anywhere.
I have installed the needed tools from RobotWare 5.12.04 and using MS VS2008 to create my application..
I hope some of you can enlighten me on this, since I really need this.
I have changed  the RMQ Type to remote as per what the manual says.
I followed the manual regarding messaging. So I thought that it should work pretty easily.
Thank you
qweq2010-04-02 11:57:07
  • Hi,
    To use your Application on a real controller you need to have the RobotWare Option "617-1 FlexPendant Interface". FlexPendant Interface provides the possibility to download and run user-developed operator interfaces on the FlexPendant. Get in contact with your ABB representative and purchase that option. You need to reboot your robot controller to activate the option.
  • Thank you for your reply..
    I figured out howto add it in robotstudio.
    And I hope my university have this addition :)
  • Hi,
    Can you tell me how you solved this problem? Cause I'm having the same problem that you had.
    I'm also working on a bachelor project to make the robot follow an object with a 3D time of flight camera.
    I'm also having a warning : RMQ message discarded.
    Regards,
  • Sorry for the late answer...
    Hope you can still use it
    I basicly, just used the build function to build a robot from a template and added the interface..
    Build station --> choose interface..
    Also, remember to start the rapid task and move the PP to main,
    at least this is what I have experienced makes the warning go away
