API: ComboBox with Workobjects
Hello
I have made a ComboBox that I fill with all workobjects that are in the active task but i would like to refill it when the user adds a new workobject to the task.
//Get all workobjects
cbParentWobj.Items.Clear();
cbDispWobj.Items.Clear();
foreach (RsDataDeclaration rsdd in stn.ActiveTask.DataDeclarations)
                if (rsdd.DataType == "wobjdata")
                    cbParentWobj.Items.Add(new CommandBarComboBoxItem(rsdd.Name));
                    cbDispWobj.Items.Add(new CommandBarComboBoxItem(rsdd.Name));
                    //Select the active workobject
                    if (rsdd.Name == stn.ActiveTask.ActiveWorkObject.Name)
                        cbParentWobj.SelectedIndex = cbParentWobj.Items.Count - 1;
                        cbDispWobj.SelectedIndex = cbDispWobj.Items.Count - 1;
Are there any good events that I can use that fires when a new data declaration is made?
Or are there any ready data collections with all workobjects that will be updated?
There are a similar combobox under home and settings. I would like the same function as that one.
  • Hi Patrik,
    I would recommend using the ComboBox.DropDown event to re-fill the combo when the user clicks it. That way you don't have to depend on RS events to keep the contents in sync.
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
  • Perfect I will try that tomorrow..
  • I used the DropDown event and it works good for my scope of use..
