RobotWare Arc
Hello together,
we use a IRC 5 controller with RobotWare Arc with one AW system.
On the Manual Functions is a button for feeding of the wire (Stickout 15 mm).
When I tap the button the system feeds only 5 mm instead 15 mm like discriped and I'm sure that nobody has change something.
My question:
Is it possible to change the value for the Stickout (15 mm) to an other value?
If yes, what's the correct way to do it?
Greetings
goofie
  • not sure exactly where the parameter is if your not using a fronious power source.
    but in configuration/proc/fronius arc equipment properties/fr5000mw_T_rob1/
    I have a parameter time to feed 15mm wire (in seconds) and you just set this to whatever you need to get 15mm of wire.
