auto configtion warning
BOKAVAN
i use create path on cube
i click auto configuration
it works but program show warning
No valid configurations found. 4/25/2010 7:30:21 AM General
and move along path didn't work
Hi Bokavan,
Try to assign first configration value of your first point in path manually and after that execute auto configration.
charon2010-04-25 14:39:24Erdem Karaçeper0 -
i did that
here all project video highly compressed with 7zip
webwiz/3326/sa.zip
the same error
http://www.7-zip.org/download.html
Hi,in the video you can see the erro: close to singularity !So start the path with a MoveJ instruction and it should work//Volker0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
