MoveAbsJ/MoveJ joint interpolation
Hello everyone,
Let, for example,
var jointtarget j1:=[[-90,  0,-60,  0,-30,  0],[9E9,9E9,9E9,9E9,9E9,9E9]];
var jointtarget j2:=[[-80,10,-50,10,-20,10],[9E9,9E9,9E9,9E9,9E9,9E9]];
var robtarget r1;
var robtarget r2;
r1:=CalcRobT(j1,tool0);
r2:=CalcRobT(j2,tool0);
Let the robot be at j1 (i.e., at r1).
What is the profile of the six joint values during the execution of
MoveAbsJ j2,v100,fine,tool0;
or
MoveJ r2,v100,fine,tool0;
I know that in both cases, all joints start and finish at the same time, so I always thought that after acceleration and prior to deceleration, the profile for each joint is linear, but I was surprised to see that it is not. In fact, in some cases, a joint that has to go from say 10 to 30 degrees, will first go to say -5 degrees and then to 30 degrees.
Does anyone know details on the actual trajectory planning? I want to be able to foresee the path of a robot in a MoveJ or MoveAbsJ motion. Is this some kind of an approximation of the minimum-time trajectory?
Thanks,
Ilian
  • lemster68
    lemster68 ✭✭✭
    Greetings,
    Is it by chance that the robot wrist is at some point directly above the center of axis one?  This is an additional robot singularity, I have seen axis one swing around quite a bit with a MoveJ instruction in these cases.  A MoveAbsJ cures that.
    Lee Justice
  • Hi,
    I did some further tests and I realized that I was wrong. Besides, it is clearly explained in the ABB manuals that the central portion of the joint-space trajectory of any joint is linear, during a MoveJ (or MoveAbsJ) motion. And you are right -- there are exceptions when near singularities.
    By the way, you are referring to what is called a "shoulder singularity," which in the popular inline wrist six-axis robot occurs when the distance between the center of the robot and the axis of joint 1 is minimum. See slide 27 of my lecture notes: http://www.gpa.etsmtl.ca/cours/gpa546/Notes/Cours11.pdf
    Cheers,
    Ilian
