TCP/IP
Hello everybody!
I am working at a school project, which is about providing quality control in a process by using image processing ( NI LabView ) and an ABB robot.
I've done the image processing algorithm and I have the coordinates of the bad parts and I just have to send them to the controller robot Stern Smile, which I don't know how:
so...I would be grateful if you can provide me some tips or point some documentation where I can find how to connect a PC to the robot controller using TCP/IP and some information on how to access the received information from RobotStudio.
Thanks. Have a nice day
  • Hi Mircea!
    I'm working in something just like that, using LabView and IRC5 over an Eternet connection.
     So, I need to know a little more to plenty help you.
     Have you already stabilished the connection between the 2 systems using sockets?
     If you haven't, its a great stating point. First you'll have to decide who will act as a server and ho will be the client. I used the robot as the server an dhe LV as the client. In fact, as long as I could understand, in therms of dataflow, there is no realy any difference in wich one is the server or the client. Take a look in the Socket related rapid instructions, such as SocketCreate, SocketBind, SocketConnect, SocketAccept, SocketSend and others. In LV you will also have to create sockets. I used the TCP Open Connection vi.
     Once you already know thebad part position, create the robot program for it to keep the arm in a "resting" position. Use the MoveL or MoveJ with the Offs option. This Offs function allows you to move the arm according to an XYZ offset from the desired position.
    Ex: MoveL Offs (Rest_Position, BadPart_X, BadPart_Y, BadPart_Z), zone,
    speed, wobject
     This would move the arm from the rest position to the bad part
    position, but it will keep the tool orientation. If you need to reorient
    the tool, it will be a litte more difficult, but it is perfectly
    possible. When there are no bad parts in the process, all you'll have to
    do is resetting BadPartX,Y and Z to 0 and the arm will return to the
    rest position.
     Thus, build an state machine or any other program structure to organize your dataflow and moving  sequences. Your LV software must pass to the robot the XYZ coordinate of the desired part. Maybe, the most anoying thing to do will be this dataflow structure. At least in my application it was... You will need to create a kind of protocol for the robot controller to recognize correctly wich data you are sending to him.
     If you want a more sofisticated solution, you can send the whole robtarget variable to the robot controller. If you don't really need to control the tool orientation, I think it's worthless to try this. Except, of corse, if you want to learn some more tricks!
     I hope this rough explanation could give you some light in your problem. If you need some more details, just let me know.
    Best regards
    Leo
    leonardolt2010-04-29 17:01:33
  • Hi Leo!
    First of all I would like to thank you for the explanation and for your advices.
    I didn't established the connection between LabView and RobotStudio, yet.
     I will read the Socket related information that you specified and I'll try to use them in RobotStudio, considering what you said.
    I have the bad parts coordinates and the orientation, but for starting I'll try without re-orienting the tool.
  • Ok, Mircea, you're welcome.
    If you want some piece of code to guide you through your own implementation, just tell me.
    Leo
  •  As may be other people interested in this TCP/IP communication between LV and RobotStudio, i'm putting here some code I used to create in Rapid the sockets needed to handle this communication.
     The first one belongs to
    the initializing funcion and is just related to the calling of the open
    connnection routines. The other ones are for effectively open, send and
    receive data. I tried to put all in english, but as I'm brazilian, maybe
    there are some text I did not realize that were left in poprtuguese.
    Sory in advance!
    ! Open TCP/IP connections
    OpenTCPServerConnection;
        OpenDebugServerConnection;
        IF
    SocketGetStatus(Client_Socket) <> SOCKET_CONNECTED THEN
        OpenTCPClientConnection;
        ENDIF
        IF
    SocketGetStatus(ClientDebug_Socket) <> SOCKET_CONNECTED THEN
        OpenDebugClientConnection;
        ENDIF
        WriteDebugString
    "Debug connection activated.AD";
    PROC
    OpenTCPServerConnection()
    ! DescriA?A?o: Creates a server socket
    to the main connection
    ! Entradas: None
    ! SaA-das: None
    AlteraA?A?es: Flex  screen
    Close eventualy oppened connections
        SocketClose Server_Socket;
    SocketClose Client_Socket;
    ! Creates o socket server
    SocketCreate Server_Socket;
        SocketBind Server_Socket, server_ip,
    TCP_Port;
    ! Listen to and waits for the client connection (LV)
    TPErase;
        TPWrite "Waiting for conncetion at address: " +
    server_ip +", porta: " Num := TCP_Port;
        SocketListen
    Server_Socket;
        SocketAccept Server_Socket, Client_Socket
    ClientAddress := client_ip;
        TPWrite "Connection succeeded at
    address " + client_ip;
    PROC
    OpenDebugServerConnection()
    to a debug channel
    ! Entradas: Nenhuma
    ! SaA-das: Nenhuma
    Close eventually oppened connections
        SocketClose
    ServerDebug_Socket;
        SocketClose ClientDebug_Socket;
    ! Creates
    socket seriver
        SocketCreate ServerDebug_Socket;
        SocketBind
    ServerDebug_Socket, server_ip, Debug_Port;
    ! Listen and wait for the
    client connection
    server_ip +", porta: " Num := Debug_Port;
        SocketListen
    ServerDebug_Socket;
        SocketAccept ServerDebug_Socket,
    ClientDebug_Socket ClientAddress := client_ip;
        TPWrite
    "Connection succeeded at address " + client_ip;
    PROC
    ReadTCPData()
    ! DescriA?A?o: Reads incoming data from the TCP
    connection.
    ! Entradas: None
    ! SaA-das: None
    AlteraA?A?es: None
    Clears input buffer.
        ClearRawBytes InputBuffer;
    ! Reads data
    from the oppened connection.
        SocketReceive
    Client_SocketRawData:= InputBufferTime:=TPC_Timeout;
    ! Got an
    error?
        ERROR
        IF ERRNO = 0 THEN
            int_data1 := 0;
    ELSEIF ERRNO=ERR_SOCK_TIMEOUT THEN
            SkipWarn;
        !TPWrite "Receive Timeout";
    RETURN;
        ELSEIF ERRNO = ERR_SOCK_CLOSED THEN
            SkipWarn;
            TPWrite "Socket closed error.
    Program terminated.";
        EXIT;
        ENDIF
    PROC
    SendFloat4(num DT, num Data)
    ! DescriA?A?o: Sends a 4 bytes float
    value trhough the TCP connection.
    ! Entradas: DT: 8 bits code
    that identifies DataType of the value. Ex: X coordinate, Y coordinate
            Quaternion value, etc.
                Data: 4 bytes float
    value to be sent.
    ! SaA-das: None
    ! AlteraA?A?es: None
    Preparing data pack:
    ! Clear output buffer
        ClearRawBytes
    OutputBuffer;
    ! Add the StatOfPacket marker (#)
        PackRawBytes
    PackStart, OutputBuffer, PackStartOffsIntX:= USINT;
    ! Add DataType
    field
        PackRawBytes DT, OutputBuffer, DataTypeOffsIntX:= USINT;
    Add Data field
        PackRawBytes Data, OutputBuffer, DataOffs
    Float4;
    !    PackRawBytes Data, OutputBuffer,
    (RawBytesLen(OutputBuffer)+1) Float4;
    ! Send data pack
    SocketSend Client_Socket RawData := OutputBuffer;
     The
    TCP/IP connection goups together data received in a certain period in a
    big bulky data frame.
     That's why I used a start of packet marker
    (#) preceeding the data type identifier and the sent value.
     The sent
    packet gets like this: |#|DataType|Value|. The receiver buffer, after
    two sending opperations,
    seems like this: #a$fA?A?#A35n'A?
     Another
    thing that is important to be said is that IRC5 input buffer seems to
    suport large data.
     On the other hand, you can only read 1024 bytes
    at once, because that's the RawBytes size limitation.
     So, you will
    need to handle your communicatoin cycle with special care, because if
    you receive more than 1024 bytes, you will have a reading index error.
     I think this is good satarting point. If anything else is needed, feel free
    to ask me.
     Best regards
     Leo
  •  There are some things that must be planned before you ecffectively starts working with sockets.
     In a previous stage you must decide witch side will be the server and
    witch will be the client. I'm not a specialist on TCP communication, so I
    don't know what mus be considered when deciding who will be server and
    who will be client. One thing I know is that the server must be started
    first, because it is necessary it to be already running when client
    attempts to connect.
     It is also important to create a kind of protocol for communication. Here I mean a high-level protocol, not those bit checking and handshaking stuff. With the socket connection you will receve a stream of bytes, so you must organize the set bytes in order to be able to restore them ant the receiver. For fixed lenght and data you can ude a very simple one, as first 4 bytes are X and second 4 are Y. But this is a very stuck way and one may prefer a more flexible one, such as: [Marker][Lenght][DataType][Data]. This is a bit harder to code, but allows you to work on further improvements on your communication channel.
     So, with those in mind, the first step in a MAIN routine is to open the socket and await for the connection. Once the connection is stabilished you are ready to transmit and receive bytes using your protocol. So, there is no other but that you need to close sockets when you are not using them any more.
    Any other points, feel free to ask, preferebly by here.
    Leo
  • In my opinion, the PC or device the robot communicates with would be the SERVER, and the robot a CLIENT - this way, if required, multiple robots can connect to the same server, and most Cognex Cameras wtih TCP/IP for expample provide a very nice SERVER implimentation. Since the robot acts more like an interpretor, and without the use of multitasking - it makes more sense for the robot(s) to be clients.
    Regarding protocal of communication, with many or multiple response combinations required, I find it easier to format all communication responses from the server in strings - preferably CSV - comma seperated variables and parse that string response in RAPID - you can then deal with numerical and ascii respoonses in the same response, and based on the number of "nums" and "strings" in the parsed string determine what kind of response has been received - since most applications can either respond with location, inspection, status or fault responses from the server application.
    Using CSV string responses makes the applicaiton more suitable to debug and logging responses than using raw packed bytes etc. - which can be useful in certain situations.
    Thomas J2012-08-23 15:33:40
    Thomas H. Johnston
    PACs Application Engineer
  • Thankyou for adding your comments Thomas. I think it will be helpfull for people trying to stabilish TCP/IP connection.
    About using the CSV I totaly agree with you when the information exchanged has a deterministic sequence and content. But when it's up to send non deterministc types of data and whitout a specific formating, I think rawdata packs used like messages could be more suited. As you said, it depends on the situation!
    Best regards, Leo
