Rapid code to generate a backup.
TriggMeL
I want to have my robot automaticaly generate a system backup. Is there rapid instructions for this that I can add to my main program? I don't need to backup to a network drive, simply adding it to the default backup directory on the controller will sufice.
Mel
Hello,That functionality is not available right now, but there is a new function in RobotWare 5.13 that does this. Robotware5.13 will be released in Q2 this year, so please be patient!BR frpa0
I downloaded 5.13 and interested in the rapid backup function. Do you know where I can find exaples or literature on this?0
System Input/Output for Backup
A new System Input called Backup is available from RW5.13. When a digital I/O signal connected to the System Input Backup is set a backup will be started. Name, path and an argument telling if the backup name shall be unique or overwritten, must be configured.
A new System Output called Backup in progress is available from RW5.13. The digital I/O signal connected to the System Output Backup in progress will be set while a backup is in progress.A new System Output called Backup Error is available from RW5.13. The digital I/O signal connected to the System Output Backup Error when the system detects a backup failure.BR0 -
This autobackup feature works great. Way to go ABB!!Mel0
