rslib data export
Hallo,
does someone knows a way to export the rslib data or a whole station to a complete CAD file?
is there any way?
thanks for help
/br
Yannik
  • To export the data from an rslib, disconnect it, select a Part, and pick "Export Geometry" from the context menu. If the geometry (i.e. the CAD data) is present you can export to SAT. Otherwise, you can export the graphics (i.e. the triangles) to .rsgfx (internal format) or .obj (see http://en.wikipedia.org/wiki/Obj)
    There is no feature to export a complete station in one go.
    ABB
