Set a text property of TpsLabel
I want set the text property of a TpsLabel component. It works on virtual controler very well, but on real controler not. I use RW5.13.0225. See following lines.
_Test.SetValue(
"3", true);
this.lMode.Text = "Grundstellungsfahrt";
_Test.SetValue(
"31", true);
In real controler the variable _Test is 3. I get also no exception.
Please, help.
granale
  • The variable must be declare in the controler as PERS.
  • ...yes I know. That is not the problem. My problem is, the 3rd line in my example is never called. But only on real controller!!!!
    granale
  • Hi,
    Is this code running in the UI thread?
    Carlos Martinez
    ABB
  • ...no, it isn't. Is in a subform. But the controller is in UI-Thread. Also the Variable-Object for the change event.
    granale
  • The UI can be modified only by code running on a UI thread. Even if the controller was created in the UI thread, all its events are executed in a non-ui thread. If you would want to make a change in the UI, make sure to invoke the UI thread ...
    Sample Pseudo-code ..
    // Assumming this code runs inside a TpsForm
    void MyNoUIThread (....)
        this.Invoke(new EventHandler(this.MyUIThread ), this, EventArgs.Empty));
    void MyUIThread (....)
       // Change of the UI
    Carlos Martinez
    ABB
  • Thank you!
    granale
