RS5.13 Simulation viewer
sturner
Simulation viewer does not seem to work fully in 5.13... my colleagues also reporting same problem.
The station graphic is captured but not the simulation.
Yes... the simulation was setup and run, prior to saving as viewer.
Thanks in advance for any sugestions
See http://forums.robotstudio.com/forum_posts.asp?TID=4005&KW= and see if it helps.Henrik Berlin
Yes this works... thanksThe old method in the Robot button / Collaborate... only captures the graphic and not the simulation.0
