Screen Maker error.
I am a new user trying to learn Robot Studio and Screenmaker.  I created a station in studio then opened screenmaker and then created an application and added a controller mode status and a rapid execution status to the screenmaker page. I then went to build, connect and deploy all of which say sucessful. When I go offline and select virtual flex pendant it starts with an error.
Error loading TpsViewer.dll
Additional info:
System.Reflection.Reflection.TypeLoadException: Unable to load one or more of the requested types. Retrive loader exceptions for more information at system.reflection.module.
Can you tell me where to retrive this error as it indicates, what it means and where to find screenmaker errors.  Additional info my Robot Studio install requalarly locks up and can only be closed with Task manager.
Thanks you for your help.
  • Hello,
    Can you provide some information like :
    Which version of RobotStudio is being used
    Which version of RobotWare
    Name of the ScreenMaker application
    PC and OS Settings
    Did the controller system have the PC Interface and FlexPendant Interface options ?
  • Hello Abhishek,
    It is robot studio 5.13 and the included screenmaker and Robotware (I do not see where to click to confirm version for Robotware and screenmaker). The OS is XP pro.
    When I select deploy a message box appears and says that the flexpendant interface controller option is required to view the application on the flexpendant. I do not know where to go to add this. We purchased the robot studio software licence with the screenmaker option.
    Thanks,
  • Hello,
    RobotStudio Offline can be used to create, program and simulate robot cells and stations.
    For online programming, RobotStudio helps to supervise, install, configure and program a real robot controller.
    Applications created from ScreenMaker can be deployed on to Virtual Controller(Offline) as well as Real controller(Online).
    Inorder to connect and deploy to a controller, a system needs to be created. Create the system using System Builder.
    If you want the application to work only on Virtual Controller, create a system using virtual robotware key and then select PC Interface and FlexPendant Interface as options.
    If you want the application to work on Real controller than a system should be built with real robotware keys which should have the FlexPendant Interface option.
    You can contact ABB Sales for information on getting this option as part of the key.
  • Thanks Abhishek,
    I appreciate your help. It would be great if that information was in the screenmaker documentation for new people to screenmaker and robotstudio like myself. If any ABB manual writers or support engineers read this post please consider it.
  • Hi, I would like to know if you can burn DVD using other files. This error can be caused by the file size. I suggest use less WMV file to test it. In addition, please try the following steps: 1. In Windows DVD maker, click Options2. In the Temporary file location, click Browse button, select the new folder location, and then click OK. For the best results when choosing a temporary fileCA coupons  location, choose a folder on a hard disk drive partition that has at least 5 gigabytes (GB) of available disk space and a fast write speed. 3. You can also change the DVD burner speed to another speed.4. Click OK. If the issue persists, please update your video card and BIOS to the latest version.
  • Screen Maker Error
    How can i solve this error?
    Please help me to solve this.
    Lingaa
  • Hello,
    ScreenMaker requires .NET Compact Framework 2.0 SP1 to be installed.
    Do the following checks just to be sure before re-installation:
    1. Check from Add/Remove Programs dialog if .NET Compact Framework 2.0 SP1 is installed.
    2. If you are familiar with registries , Check the following Registry Entry from Registry Editor HKEY_LOCAL_MACHINESOFTWAREMicrosoft.NETCompactFrameworkv2.0.0.0InstallRoot
    If not seen in Add/Remove programs and registry entry is not valid
    Re-install RobotStudio
             or
    Download .NET CompactFramework 2.0 SP1 from the following link http://www.microsoft.com/downloads/en/details.aspx?familyid=0c1b0a88-59e2-4eba-a70e-4cd851c5fcc4&displaylang=en and install it.
