SetProgramPointer at specified row not working
Jerome
Hi, can you tell me how to use the SetProgramPointer sub to send the PP to a specified row of a routine. Here is my VB.Net code:
aTask.SetProgramPointer(ppLastPPPosition.Module, ppLastPPPosition.Routine)
System.Threading.Thread.CurrentThread.Sleep(1000) '1000ms = 1sec
aTask.SetProgramPointer(ppLastPPPosition.Module, ppLastPPPosition.Start.Row)
I'm able to get the PP in the routine but the PP is not going to the specified row (third instruction above).
What should I do?
Jerome
What should I do?
Jerome
Can someone at ABB look at this problem Please!Thanks,Jerome0
Are you using a row number relative to the Module?
Carlos Martinez
Yes I am. I'm moving the program pointer in the routine successfully but when I try to Set it to a specified row it doesn't work. ppLastPPPosition.Start.Row is a ProgramPointer data type that return a num with the row.I'm using RAB 5.12 with a RW5.12_02.01.2043 in the IRC5.Jerome0
Can you create a simple test (C# + RAPID) ? This will help to analyze what is now working properly.ThanksCarlos Martinez
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
