VIRC5 not starting up
ReneK
when "turning on" the controller in VIRC5, we are getting a lot of times the following error:
RobVCPanel.Init failed.
Does anybody know what could cause this?
BR
Ren?
Hello Rene',
It sounds like you have some incompatibility between VIRC5 and the Virtual Controller you are using.
If you still have the problem,install the latest version of VIRC5 and try again.
Anders S38608,4535763889Best regards,
ABB Robotics0
- 858 RAPID Programming
