Question in RAB maunal
Hi all;
where to write the code in page 100 in RAB manual
that declares the secondary view
I tried to place it as a member to the class of the first view ---> gives an error
then tried to place it as a member to the class of the second view --->gives the same error
the error is in the line:
private View2 _view2;
and the error is :
Error    1    The type or namespace name 'View2' could not be found (are you missing a using directive or an assembly reference?)    C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs    15    17    TpsViewIRC5App4
so where to place the declaration of the secondary view ???????
thanks in advance.
mostafa mokadem2010-06-29 00:48:45
  • now, I typed the code in page 102
    the error becomes in line:
    public View2(ABB.Robotics.Tps.Taf.ITpsViewLaunchServices ls)
    Error    1    Class, struct, or interface method must have a return type    C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs    59    16    TpsViewIRC5App4
  • I downloaded RAB 5.13 manual
    this example is as it is. Unhappy
  • HI,
    Could you try to change the name of the class?
    If this does not work, could you zip and upload the project?
    BR
    Carlos Martinez
    ABB
  • webwiz/3292/TpsViewIRC5App4.rar
    attached the file containing an Error.
    thanks in advance
  • when changing class name the error becomes in the line
    this._view2 = new View2();
    Error    1    No overload for method 'View2' takes '0' arguments    C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs    26    27    TpsViewIRC5App4
    mostafa mokadem2010-06-29 17:27:05
  • Hi again,
    I will double check the updates made compared to the installed version of the manual.
    Thanks for your patiance.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
