Question in RAB maunal
Hi all;
where to write the code in page 100 in RAB manual
that declares the secondary view
I tried to place it as a member to the class of the first view ---> gives an error
then tried to place it as a member to the class of the second view --->gives the same error
the error is in the line:
private View2 _view2;
and the error is :
Error 1 The type or namespace name 'View2' could not be found (are you missing a using directive or an assembly reference?) C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs 15 17 TpsViewIRC5App4
so where to place the declaration of the secondary view ???????
thanks in advance.
mostafa mokadem2010-06-29 00:48:45
now, I typed the code in page 102
the error becomes in line:
public View2(ABB.Robotics.Tps.Taf.ITpsViewLaunchServices ls)
Error 1 Class, struct, or interface method must have a return type C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs 59 16 TpsViewIRC5App4
I downloaded RAB 5.13 manual
this example is as it is.
HI,Could you try to change the name of the class?If this does not work, could you zip and upload the project?BRCarlos Martinez
when changing class name the error becomes in the line
this._view2 = new View2();
Error 1 No overload for method 'View2' takes '0' arguments C:Documents and SettingsmostafaMy DocumentsVisual Studio 2005ProjectsTpsViewIRC5App4TpsViewIRC5App4TpsForm1.cs 26 27 TpsViewIRC5App4
mostafa mokadem2010-06-29 17:27:050 -
Hi again,I will double check the updates made compared to the installed version of the manual.Thanks for your patiance.0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
