SpeedRefresh
Is there a way to return the Robot speed to 100% if the Operator has set the speed to 50% from TP? If an operator changes the speed override from the TP, I want it to default back to 100%. The "SpeedRefresh" instruction works to lower the speed, but only works to increase the speed up to the speed set from the TP (i.e., if TP speed = 70%, SpeedRefresh 100; will not return the robot to 100%). <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have done something similar before without any problem.
First I read the current speed override, then slowed the robot down if necessary:nNormalSpeed := CSpeedOverride();
!If slow speed less than current speed reduce to slow speed
If nNormalSpeed>nSlowSpeed THEN
SpeedRefresh nSlowSpeed;
ENDIF
Later I would return to the normal speed with
SpeedRefresh nNormalSpeed;
This worked fine with the normal speed being 100%0 -
Moved to RobotWare forumHenrik Berlin
I don't know the answer to this question, but from a safety perspective I think it would be a safety risk if the RAPID code can override the speed reduction defined on the FlexPendant. I doubt that this is possible.Henrik Berlin
ABB0
