Newbie- Event Manager
Hii
I want to perform simple task of motion using I/O signal but I am not able to find event manager as used in Video tutorial. Created signals are not recognized in Rapid code if used.how to do it then??
Thanks..
Thanks..
Is this a RobotStudio question? Which tutorial are you referring to?Henrik Berlin
yes , I am using Robotstudio only and i was referring to video tutorial "Station signal and Event manager" uploaded on Robostudio community .
I created input signals for my station from Simulation--> I/O simulator but when I use them in Rapid program ,it shows error - unknown reference.
Is there any procedure to enable I/O signal??
You must define the signal in the robot controller to use it from the RAPID program. Remember to declare your signals with Access level ALL to enable them to be used from RobotStudio.
The event manager is available in RobotSTudio 5.13, but slightly hidden as we want to promote the new concept of Smart Components (see tutorials). But you can bring up the Event Manager by pressing the small arrow on the "Congfigure" group of the Simulation tab, see also picture below.
ABB0
