Interrupts not working after Power Failure?
tbaumg
We recently had a customer with a robot that experienced a power failure. After the failure they restarted the robot and it crashed into a retractable blade guard that normally is controlled & verified by an interrupt routine.
After further testing we discovered that interrupts that are connected to TRAP routines do not automatically reconnect after a power failure.
According to the RAPID Technical Reference manual:
All interrupts in a task are cancelled when program pointer is set to main for that task and must be reconnected. The interrupts will NOT be affected by a power fail or a warm start. <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Any help or advice would be greatly appreciated.
Thanks,
Toby
Moved to RobotWare forum.Henrik Berlin
I suggest you get in touch with your local ABB representative in this matter.Henrik Berlin
ABB0
- 365 IRC5
- 84 OmniCore
