question about PC SDK
Hi all,
I have a question about PC SDK.
Can I use PC SDK in the virtual environment ?? ( without using neither FP SDK nor the virtual FP )
I mean that is it possible to manage the virtual controller & the virtual manipulator in the offline-state in robot studio using an application developed using the PC SDK ??
Thanks alot.
Thanks alot.
Yes, you can connect to a virtual controller in Robot Studio from a PC-SDK application.Lennart H0
You can either develop a stand alone PC SDK application (MyApplication.exe) or develop an Add-In to RobotStudio (MyAddIn.dll) which is loaded into RobotStudio.exe, and from which you can perform PC SDK communication.If you are a beginner, I think its easier to start with a stand alone PC SDK application.And of course it depends on what you want to achive with your application.0
thanks a lot
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
