Simulation speed up
NFC
With RS4 I was ale to simulate a program that normally would take 25 minutes in just 2 or 3.
Is there a way, like in RobotStudio 4, to increase significantly the simulation speed?
Thank you,
Nils.
Yes, In your robot studio options:simulation:virtual time select Free Run.
j_proulx2010-07-07 23:18:18Options:Simulation:Virtual Time Virtual Time mode- Free run This option makes RobotStudio always use the free run mode. Virtual Time mode - Time Slice This option makes RobotStudio always use the time slice mode. 0
