change language on flex pendant
hallo all,
does anybody know if you buy a robot if then all languages are included or not.
I have a robot on which I can select English, german and chinees,..... but would like to have the flex pendent in tsjech language.
if I load the software key in systembuilder, I can see that indeed the robot has the option for english, german and chinees language.....but further in options, I can pick whatever language I want. Can I do so and boot the robot with this configuration or will the robot block by booting?
thx for your advise,
bart
best regards,
bart
  • English is the default language but you can always create e new system in SystemBuilder with your own choice of second and third language and this will work without any problem.
    BR//Nils-Olov
