import RobTargets to Robot Studio
heeler
I have been searching for a way to import robTargets from a rapid program module into Target Data in the Simulation paths and Targets. The robTargets have previously been created, put in an array and then are used from the array. I would like to try and put them back into the simulation so that I can visulize where the targets lie on the parts that I import.
heeler2010-07-13 18:45:12
heeler
Hi,The way to import robtarget data into a RS station, is to load the program module with the robtarget data in to a system (Virtual Controller), and then synchronize them to the station.Unfortunately does the RS synch. not support robtarget data declared as arrays, so you have to define them as "normal" robtarget data before you synchronize.Best regards,
ABB Robotics0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
