Cannot add aliases [WebWare SDK]
Hi.
After an OS setup (XP), it is not possible to add devices into the device configurator. SDK repair has been done without results.
Virtual console works, virtual robot conf works.
Error messages into the event log are
Event Type: Information
Event Source: ABB Interlink Module
Event Category: None
Event ID: 26
Date:  9/19/2005
Time:  3:52:19 PM
User:  N/A
Computer: xxx
Description:
WWClient Information: [Original State: WWC_STOPPED] [New State: WWC_DISCONNECTED]
Event ID: 26
Date:  9/19/2005
Time:  3:52:19 PM
User:  N/A
Computer: STP-NBGARDONID
Description:
WWClient Information: CoCreateInstance failed to create DataCollector COM object: local COM server status = 0x80040154 (Class not registered
), remote DCOM server status = 0x80040154 (Class not registered
Thank you in advance for helping me, Davide
Davide
  • Hi Davide,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    Which version of Windows XP do you have?
    If you have Windows XP SP2 you can try the beta of WebWare 4.6.
    Are you using WebWare Server or WebWare SDK, the WebWare Client DCOM error is WebWare Server related?image
    Try to uninstall WebWare and reinstall it again, the repair is not always working.
    Thomas Andersson
    Support Engineer
    ABB Automation Technologies
    ATMA/RO/AIS
  • Hi.
    Thank you very much for your reply.
    It is true, repair did not work, but complete unistall/reinstall had solved the problem.
    Best regards
    Davide
    Davide
  • Hi again Davide,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    You are welcome.image
    Thanks for the information.image
    Thomas Andersson
    Support Engineer
    ATMA/RO/AIS
