Movingo CAD model after programing
ronaca88
Hello there. Im new in this forum and I really want to learn how to use robotstudio in a professional way.
Here is my problem. After I creat a whole path through a CAD model, I want to move the CAD model to another position.
Is there a way to refresh the targets to the same position or I have to creat the whole path again?
Hi! You can attach the workobject (not wobj0) you have created your targets in to the CAD model. Then will the workobject and the targets follow the CAD model when you move it.If you have created your targets in wobj0, create a new workobject, attach it to the CAD model, then drag your targets to the new workobject.Best regards,
Thanks you! you were very helpful
Hi, is it possible attach only Object Frame?0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
