TCP/IP disconnect not handled correctly
jeroen
I have a TCP/IP connection between my robot to a control program running on a PC. The code below runs in a separate semi-static task.
If I physically disconnect the robot (plug out cable), after a while this task crashes on the SocketSend function call shown below.
The socket_status keeps reporting SOCKET_CONNECTED however.
How can I fix/work around this?
Regards,
! Send status to client.
TRAP TrapStatus
VAR socketStatus sockStat;
sockStat:=SocketGetStatus(client_socket);
IF sockStat=SOCKET_CONNECTED THEN
SocketSend client_socketStr:=Status+ByteToStr(13Char)+ByteToStr(10Char);
ELSE
! Connection lost?
ENDIF
! Acknowledge.
SetDO doStatus,0;
RETURN;
ERROR
!TryNext;
! Acknowledge.
SetDO doStatus,0;
RETURN;
ENDTRAP
Moved to RobotWare forum.Henrik Berlin
I've been working through this myself, and I think I can help. SOCKET_CONNECTED will be true unless the client or server explicitly closes the connection. However, if the cable is unplugged, you should be getting a Timeout Error. You can handle error with the following error catcher:
ERROR
IF ERRNO=ERR_SOCK_TIMEOUT THEN
Just be careful not to spend too much time in your TRAP, as I believe code ignores any other interrupts while inside a TRAP.
Hallo jeroen.
In your topic I see you are writing TCP communication. I want to make TCP server on the server side. Do you know if is posible to start new thread with socket (returned by SocketAccept fnc) ? Your code looks working like this.
thanks for help.
What exactly do you mean by a new thread?
I don't think you can make a server with a thread for each connection; you just have to handle all connections in the same task.In my application I just need to handle a single connection.I have a ServerStart procedure:
PROC ServerStart(bool Recover)
IF Recover THENLog "ServerStart with recovery need";SocketClose server_socket;
SocketClose client_socket;
ELSE
Log "ServerStart without the need for recovery";
ENDIF
SocketCreate server_socket;
SocketBind server_socket, IPAddress, IPPort;
SocketListen server_socket;
Log "Wait for connection";
SocketAccept server_socket, client_socketClientAddress:=client_ipTime:=WAIT_MAX;
Log "Connection with " + client_ip;
ERROR
Log "ERR_SOCK_TIMEOUT";
Retry;
ELSEIF ERRNO=ERR_SOCK_CLOSED THEN
Log "ERR_SOCK_CLOSED";
Return;
ELSE
Log "Unknown error"ENDIF
And in the main loop I handle the server like:ServerStart(FALSE);-- Some more initializationjeroen2012-01-26 15:22:43
WHILE TRUE DO
SocketReceive client_socket Str:=ReceiveTime:=nHeartbeatTimeout;
Log Receive;
! Process data
ENDWHILE
ERROR
Log "Timeout";
! Close connection and restart.
ServerStart(TRUE);
Retry;
Log "Socket closed by peer!";
ServerStart(TRUE);
Retry;
ELSE
Log "Unknown error";
ENDIF
ENDPROC0 -
Hi there!I'm quiet new to RAPID, but I spent some time on developinga TCP-based communication from client-PC to server-IRC5.just a thought:If you have the option "Multitasking" installed, you can use some additional tasks for separate server sockets that listen continously for incoming data.You can try to useResetRetrycount;in your error handling rigth afterServerStart(TRUE);The standard number of retry counts is 4 (configurable somewhere ...), so after four times of handling the same error, theRetry;will not be executed and the loop/proc will come to end/be finished.hope this might help!?0
