Strange error tooldatanot type name
After adding a persistant variable for tooldata in RobotStudio 5.13.10, I get a strange message:
/IRB6400R_200kg_2.5m/RAPID/T_ROB1/VisSearch(9,3): Error 82 : Reference error : tooldatanot type name
Clearly, tooldata IS a type name, but I'm not sure what I'm doing wrong here.
Has anybody seen this message before?
Here is the line where I added the tooldata:
  PERS tooldata toolVisSensor:=[TRUE,[[2.52159,158.11,336.934],[1,0,0,0]],[10,[0,100,300],[1,0,0,0],0,0,0]];
TIA to anyone who can shed some light...
  • Try changing the name of the tool to something that hasn't got the word "tool" in it. I think "tool" may be a keyword. I seem to recall similar issues in the past, but it was a while ago. Worth a try anyway.
  • That seems reasonable, but I noticed a couple of things:
    D'oh!
    When I looked for things named ...tool... I found my error.
    I made a function and transposed the function name and the returned datatype.
    This apparently polluted the keyword "tooldata", so that Robotstudio thinks it's no longer a datatype name--because ALL the tooldata declarations became bogus (it only tells you about the first one).
    so, changing
    FUNC RelToolData tooldata ...
    to
    FUNC tooldata RelToolData ...
    fixes it.
    Thanks!!
    (although, I must comment that the error message was sort of misleading!)
