Where I get the kxt files for IRB4600 simualtion
snailboy
Dear sir,
I download the IRB4600 rslib files in library,but no kxt files attached, so I can not do the simulations, where can I get the kxt files to continue the simulation.
Best Regards!
Steven Xu
Johannes Weiman
Hi Johannes,Very thanks for your help!BR/Steven0
Dear sir,I have a IRB5400-02 robinstall files in library,but no kxt files attached, so I can not make a system file and startup file for robot, where can I get the kxt files to continue the making It .Best Regards!0
You can create systems for all supported robot models using the System Builder and use them for offline programming in RobotStudio. To download a system to a physical controller you need a real system key. Normally, this comes with your robot installation.However, I am not familiar with the version IRB5400-02 and to my knowledge it is not supported by RobotWare. To my knowledge, the IRB 5400 series comes the following versions:
- IRB 5400-12, Slim arm
- IRB 5400-13, Slim arm on Clean-wall rail
- IRB 5400-14, Slim arm on In-booth rail
- IRB 5400-22, Process robot
- IRB 5400-23, Process robot on Clean-wall rail
- IRB 5400-24, Process robot on In-booth rail
ABB0 - IRB 5400-12, Slim arm
hi Dear HenrikI have robinstall program and i making system and program for Robot ABB, but iwhen i attach keystring in robinstall for making PA servis, not support my key.Do you have key for this problem ?a.abaee0
RobInstall is used to create systems for S4 robots and the System Builder in RobotStudio is used for IRC5 robots. Do you have an S4 robot or an IRC5 robot?
S4 Robot0
my screenshot0
