Creating EIO file in a Robotstudio (Virtual mac)
stud.bs
I have created a Project on robotstudio using IRB660 robot and I was trying to load a EIO files I created. The eio file has two omron devicenet nodes tht I defined and declared inputs in it. But as soon as I loaded it on Robotstudio 5.13.01 it would load it but as soon as you restarted the machine, it would wouldnt reload and would get stuck in the undefined state.
Please have a look at the EIO file creted. and also I have included the Robostudio project. http://www.sendspace.com/file/4z42qw
The Task Program
http://www.sendspace.com/file/lnuere
The robostudio Project file can be downloaded from this link
http://www.sendspace.com/file/uyles8
The Task Program
Bharat Suvarna
Try this:EIO_UNIT:-Name "BOARD10" -UnitType "d652" -Bus "Virtual1" -DN_Address 10-Name "BOARD11" -UnitType "DN_01" -Bus "Virtual1" -DN_Address 11-Name "BOARD12" -UnitType "DN_02" -Bus "Virtual1" -DN_Address 12
#Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hi Knud,
I have loaded the files and then did a restart of the system , but evn then I found that This error occurs. I have included an image of the error.
Bharat Suvarna0 -
dit you cange to virtual bus system ?Try this:EIO_UNIT:-Name "BOARD10" -UnitType "d652" -Bus "Virtual1" -DN_Address 10-Name "BOARD11" -UnitType "DN_01" -Bus "Virtual1" -DN_Address 11-Name "BOARD12" -UnitType "DN_02" -Bus "Virtual1" -DN_Address 12
#Regards
Knud Erik Lindberg
The problem is that the controller system lacks the "DeviceNet" RobotWare option. An alternative to Knuds solution above is to modify the system to include the DeviceNet option. When doing this, the station referencing the system must not be opened.Important: For the change to take effect, the system must be I-started, after the station is loaded next time.Henrik Berlin
Thank you Knud and Henrik for your responses.
Could you let me know how I can change the system to include the devicenet without opening the station.
Could you give me some steps on how I can change the system options.
Bharat Suvarna0 -
1. Start RS2. Go to Offline tab3. Start System Builder4. Point out your system5. Select 'Modify System'6. Add the DeviceNet option in the options list.7. Open the station8. I -start the system9. Load the file EIO2.cfg10. Warm-start the system-> DONE!Henrik Berlin
Thank you All for your help. The EIO file was loaded without any problem.
Bharat Suvarna0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
