fault during system creation
Hello together,
when I try to create a system from layout I get an error from RS. (see attached picture)
Any ideas what's wrong on my RS?
  • If you upload the support log files, it might be possible to identify the problem.
    ABB
  • Do you get the problem for all robot models or only certain combinations?
    (Try an IRB120 in an otherwise empty (new) station)
    Have you installed RobotWare?
    ABB
  • Hi there,
    unfortunately, I get the problem for all robot models.
    Yes the RobotWare is installed.
    Systems, which are created earlier and with the same installation of RobotStudio, are working very well.
    webwiz/3372/RobotStudio_3828_101125_201842.rslog.rar
  • Please try to install RobotStudio 5.13.02 and RobotWare 5.13.02 and see if you get the same problem.
    ABB
  • Hi Hendrik,
    you're right with your assumption. The installed RobotWare was incorrect. I've made a renewal of the RobotWare installation and now it works very well.
    It's very strange for me, why stations which were created in the past and with the installation of RS and RW were working well. I don't get it!
    But nevertheless, many thanks for your tip.
    Clap
  • The systems created by "Template System" and "System From Layout" uses pre-defined keys. The keys are versioned by a so-called "signature". RobotWare is backwards compatible with old key signatures but not forward compatible. If the RobotWare you are trying to use does not support the key signature of the key used, you will probably get this problem. The IRB4600 is relatively new so it might be that the key signature was too new for the used RobotWare.
    A workaround might have been to use the system builder which uses the selected RW to generate a key. Then the latest key signature supported by the selected RW version will be generated.
    Old stations uses existing systems generated with your previous version of RobotStudio. The keys bundled with that version were supported by the matching RW version.
    ABB
