PC SDK
Hello guys!
I have one question about PC SDK. I would like to do PC application in c# with SDK library. Last month we got new irb 120 robot arm and now it will be use for educational purpose. Is it possible that I can write entire module and procedure in c# language and than it sends to irc5 controller or  I can send only few parameters as RobTarget, Num, Bool on controller where the program is loaded beforhand.
Thanks for help guys!
Samo
samosamo2010-12-01 22:48:39
  • Hi
    The language that you are using when you are programming the robot is RAPID. You can use C# for writing an application that will transfer modules, written in RAPID, to the robot. If you are new to the PC SDK I strongly recommend that you read the section Using the PC SDK->Create a simple PC SDK application in the attached application manual.
    Lennart H
  • I read this article. Now I start with c# programming language and PC sdk. I am write in c# next code:
    public Form1()
    {InitializeComponent();
    this.scanner = new NetworkScanner();
    this.scanner.Scan();
    info = scanner.Find(new Guid("{EEEFF971-5943-4FDE-80F8-BD10FC7797DC}"));
    controller = ControllerFactory.CreateFrom(info);
    private void Form1_Load(object sender, EventArgs e)
    if (info.Availability == Availability.Available)
    if (this.controller != null)
    this.controller.Logoff();
    this.controller.Dispose();
    this.controller = null;
    this.controller = ControllerFactory.CreateFrom(info);
    this.controller.Logon(UserInfo.DefaultUser);
    else
    MessageBox.Show("Selected contoller not availabe.");
    When the program comes to below statement
    then I get exception with next text: PC Interface option not found. Now i do not know, where is problem.
    Thanks for help!
    samosamo2010-12-02 14:32:33
  • An IRC5 controller can be accessed by a PC Application only if the system has the robotware option 616-1 PC Interface.
    BR
    Carlos Martinez
    ABB
