PC SDK
samosamo
Hello guys!
I have one question about PC SDK. I would like to do PC application in c# with SDK library. Last month we got new irb 120 robot arm and now it will be use for educational purpose. Is it possible that I can write entire module and procedure in c# language and than it sends to irc5 controller or I can send only few parameters as RobTarget, Num, Bool on controller where the program is loaded beforhand.
Thanks for help guys!
Samo
samosamo2010-12-01 22:48:39 0
HiThe language that you are using when you are programming the robot is RAPID. You can use C# for writing an application that will transfer modules, written in RAPID, to the robot. If you are new to the PC SDK I strongly recommend that you read the section Using the PC SDK->Create a simple PC SDK application in the attached application manual.
Lennart H0 -
I read this article. Now I start with c# programming language and PC sdk. I am write in c# next code:
public Form1()samosamo2010-12-02 14:32:33{InitializeComponent();
this.scanner = new NetworkScanner();this.scanner.Scan();
info = scanner.Find(new Guid("{EEEFF971-5943-4FDE-80F8-BD10FC7797DC}"));
controller = ControllerFactory.CreateFrom(info);
When the program comes to below statement
private void Form1_Load(object sender, EventArgs e)
if (info.Availability == Availability.Available)
if (this.controller != null)
this.controller.Logoff();
this.controller.Dispose();
this.controller = null;
this.controller = ControllerFactory.CreateFrom(info);
this.controller.Logon(UserInfo.DefaultUser);
else
MessageBox.Show("Selected contoller not availabe.");
}this.controller.Logon(UserInfo.DefaultUser);
then I get exception with next text: PC Interface option not found. Now i do not know, where is problem.Thanks for help!0 -
An IRC5 controller can be accessed by a PC Application only if the system has the robotware option 616-1 PC Interface.
BRCarlos Martinez
ABB0
