M98 Controller Backup into IRC5
ronaca88
Hi, Im trying to simulate an existing manufcturing cell. I have a backup of the real cell and I want to load in to the simulation. The problem is that the backup is from a M98 Controlller. How can I load this backup into Robotstudio5.13 . I already have the cell in 3D, the system configuration but no the program. How can I do it?
I never tried, but you must convert the parameter to IRC5
I this situation, I'll make a Irc5 OS, with the same options, then try to load EIO parameters, repair the problems, then I'll see the SYS file, and make a new one, with the same data. Put in HomeDir, all files form S4c that was on Ramdisk. Then I'll make a P-Start and see what happend.
It's no a good solution. Only a I can tell you, that you must do it manually, and you have to a good knowlegde of Rapid.
If you need more help, post. Or you want you can send me tha backup and I'll try to do it
/Jorge
Jorge Turiel0
