HotEdit and UIShow.
jesus
Hello.
Does anyone know what the name of file.dll of the application "HotEdit" to be called through the RAPID instruction UIShow?.
Thanks in advance.
Merry Christmas to all.
Thanks in advance.
Have you tested TpsViewHotEdit.dll?Not sure if it will work or not but maybe worth a try...Lennart H0
Maybe...MODULE MainModule
PROC main()
CONST string Name:="tpsviewhotedit.dll";
CONST string Type:="ABB.Robotics.Tps.HotEdit.TpsViewHotEdit";VAR num mystatus:=0;UIShow Name, Type Status:=mystatus;
ENDMODULELennart H0 -
OK. It's perfect.
In TpsViewHotEdit.dll see the "Name" having much luck. Comparing TpsBackupAndRestore.dll with TpsViewHotEdit.dll located in the Tps folder in the RobotWare, you can deduct the "Name", but unreadable, this after the same series of strange characters and following the same pattern of words.
It is not the most orthodox way to discover the "Name", but was effective moments after receiving your reply to my question.
If you do not mind my asking, how did you know you?.
Thank you very much for your quick and accurate response.
Jesus.0
