One or two controllers
I have two robotcells each with teir own IRC5 that I want to communicate with from my PC.
Should I use one or to controllers in my program?
  • RobotStudio can connect Online to your real (physical) IRC5 controller (RC) over Ethernet, either over the LAN (requires the RobotWare option PC Interface) or through the service port.
    In addition RobotStudio can be used for Offline programming by using one or several virtual controllers (VC) running in your PC.
    So, if you want to do Offline programming of your IRC5 controllers (RC) you should create one Virtual Controller (VC) for each RC. I recommend you to try the feature "Go Offline" of the Online tab that will automatically create a matching VC for your RC.
    ABB
  • OOps should have explained better.
    I have a program on my PC wich is online communicating with two IRC5.
    I have a problem that after a IRC has been lost, I get an exception when I triy to logon when it has been found again.
    Whats wrong?
    private void AddControllerToListView(object sender, NetworkWatcherEventArgs e)
                string tmp;
                int i = 0;
                try
                    ControllerInfo controllerInfo = e.Controller;
                    ListViewItem item = new ListViewItem(controllerInfo.IPAddress.ToString());
                    item.SubItems.Add(controllerInfo.Id);
                    item.SubItems.Add(controllerInfo.Availability.ToString());
                    item.SubItems.Add(controllerInfo.IsVirtual.ToString());
                    item.SubItems.Add(controllerInfo.SystemName);
                    item.SubItems.Add(controllerInfo.Version.ToString());
                    item.SubItems.Add(controllerInfo.ControllerName);
                    this.listView1.Items.Add(item);
                    item.Tag = controllerInfo;
                    if ( e.Controller.IPAddress.ToString() == "192.168.51.12" )
                        MyGetController_2();
                catch (Exception u)
                    tmp = string.Format("ERROR: {0}", u.ToString());
                    ErrLog(tmp);
            private void RemoveControllerFrListView(object sender, NetworkWatcherEventArgs e)
                string tmp;
                try
                    foreach (ListViewItem item in this.listView1.Items)
                        if ((ControllerInfo)item.Tag == e.Controller)
                            this.listView1.Items.Remove(item);
                            break;
                catch (Exception u)
                    ErrLog(tmp);
            public bool MyGetController_2( )
                string  tmp;
                try
                    int i = -1;
                    int iNr = listView1.Items.Count;
                    for(;;)
                        i++;
                        if ( i >= iNr )
                            break;
                        ListViewItem itemView = listView1.Items;
                        if ( itemView.Tag != null )
                            if ( itemView.Text == "192.168.51.12" )
                                ControllerInfo controllerinfo = (ControllerInfo) itemView.Tag;
                                if (controllerinfo.Availability == Availability.Available)
                                    if (this.m_ctrl_2 != null)
                                        this.m_ctrl_2.Logoff();
                                        this.m_ctrl_2.Dispose();
                                        this.m_ctrl_2 = null;
                                    this.m_ctrl_2 = ControllerFactory.CreateFrom(controllerinfo);
                                    this.m_ControllerInfo_2 = controllerinfo;
                                    this.m_ctrl_2.Logon(UserInfo.DefaultUser);
                                else
                                      SysLog( "MyGetController_2, IP not available" );
                                      return false;
                    return false;
                catch (Exception e)
                    tmp = string.Format("ERROR: {0}", e.ToString());
                    ErrLog(tmp);
                    return false;
    Bulletin Board Software by Web Wiz ForumsAr version 9.53
    Copyright Ac2001-2008 Web Wiz
  • Moved to Developer Support.
    ABB
  • Can you please screen dump/upload the exception.
    Lennart H
  • Ser du nA?got konstigt i koden?
    Hade du gjort likadant?
    mvh
    Ulf
