installing webware on xp [WebWare Server]
Hi, I am trying to install webware server on a machine with xp professional service pack 2. The system says that i can not run the server on xp pro ser pack 2. Is there a new version or do i have to change op system to windows server 2003. I have only 3 robots and would like to run the server using xp ser pa 2
Please help !!!!
Andrew
Version 4.6, which will be installable on XP SP2 Server 2003 SP1, should be available after November 1.Russell Drown0
